lainevainio kirjoitti:Mikä mättää kun BaseCamp löytää kyllä Zumon mutta Sorsa ei? Karttoja pitäis siirtää naviin, valinnan jälkeen kun klikkaa "siirrä laitteeseen" mutta ei vaan löydä. Herjaa että pitää olla Host tai Garmin-tilassa...
Mikä laite?
Kokeileppa tätä
As the Zumo 340 or 350 LM is also the same problem with MapSource, Windows 7 and Garmin Zumo 390 If you connect the navigation system to the PC (XP operating system), you can without problems things from MapSource transmitted or received by the device. The Navi is immediately found by the program. however you Utilizes a PC with Windows 7 and do not want to renounce Garmin MapSource, then one is initially posed a problem. The PC recognizes the Navi, it also shows in the computer / workstation as a mobile device. But you start MapSource, it is not recognized. Base Camp recognizes the Navi on the other hand immediately.
The navigation system is recognized under Windows 7 as a mobile device and not as a USB drive with a small matter of adjustment, the problem can however fix: 1) Start the navigation, while it can not be the PC be connected 2) In the main menu click on "map" 3) In the window that opens, right down to "pace" button 4) It will open the trip computer. Here, press the center indicator with speed and direction and hold 5) If you have pushed long enough (10 seconds maximum), opens an English view. There is now even go down. Sometime displays the menu item "MTP Settings" - click 6) In the window that opens, set the mode to convert "Mass Storage Mode" and confirm 7) Go back to the main menu on the little arrow The navigation system now to the PC -> It is recognized now also under Windows 7 in MapSource
Mikä laite?
Kokeileppa tätä
Kiitos, mulla oli sama ongelma, ja se ratkesi edellisen avulla
Mut vielä on yksi bropleema.
En saa 390:stä siirrettyä jälkiä Mapsourseen -herjaa vain että laitteessa ei ole kohdetta jäljet.
Basecamppiin jäljet siirtyy sujuvasti ja sieltähän ne toki saa kopioitua Sorsaan,
mut haluaisin kätevästi ne suoraan sinne, koska Mapsource sopii mun hanskaan paremmin
CapoSakke kirjoitti:Oletko katsonut resurssien hallinnan kautta Log ja GPX kansiot ?
Samalla voit siivota laitteen ja poistaa turhat kielet ja äänet ym....
No sieltä ne kyllä näköjään löytyy.
Mutta kaipaisin kovasti samaa ominaisuutta kuin Zumo 550
-eli piuha bärssiiseen kiinni, ja klikkaus, ja jäljet on Sorsassa.
Toki ne nytkin sinne saa, mut vaatii hiukan enemmän vaivaa...
Winkula kirjoitti:Toimiikohan MapSourse Windows 8.1 käyttiksessä?
Pitäis hommata uusi kone ja harmittaa jos Sorsa ei pelitä siinä
Kyllä tuo ainakin minulla toimii.
Miten tää oikein menee...
Saako vielä jostain/jotenkin mapsorsan uuteen koneeseen asennettua.
Jotakin ominaisuuksia tyhmälle käyttäjälle mieleisempiä kuin bacecampissa..
Molemmilla reittejä värkännyt..
